Crankshaft Pully Nut question. #997341 05/19/10 02:04 AM
toyhooter Offline OP
Whats the deal with the crankshaft pully nut removal. I read the tech threads and I see that it's dificult to remove. Do you need to remove it for a timing belt job? I was thinking that it would only be a problem if I was pulling/rebuilding the engine.
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: Crankshaft Pully Nut question. [Re: toyhooter] #997342 05/19/10 04:46 AM
You have to take it off the get the lower timing belt cover off to replace the timing belt. It's easy to get off. Just use a half inch breaker bar and rest it on the frame rail and do a light bump on the starter, and it comes loose. Torqing it back down requires some way to hold the pulley/crank still while you honk on the wrench, or cheat and bash the tightening wrench with a dead blow hammer.
Re: Crankshaft Pully Nut question. [Re: fasteddy] #997343 05/19/10 06:15 AM
I see. That really bites. Dealer maintenance engineering. Like jacking up the engine to get to a few plugs. Or using a special tool that resembles an alien probe to get to a few plugs. Thanks.
ToyHooter
90 LWB Montero
Bart Simpson
Re: Crankshaft Pully Nut question. [Re: toyhooter] #997344 05/19/10 07:22 AM
justice Offline
Some pulleys have two holes for a "Special Tool" that you insert into the holes to hold it still while tightening the bolt. If you have a welder you can make it with a couple of bolts, a grinder and a piece of angle iron. Others here have made one with a couple of pieces of flat stock bolted together. Or you can use a chain wrench and piece of belt to cushion the chain.
Re: Crankshaft Pully Nut question. [Re: toyhooter] #997345 05/20/10 12:53 AM
Cool. Thanks for all the info. Saved and printed.
ToyHooter
90 LWB Montero
Bart Simpson
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-14 06:25:15 UTC
