Rating: 2
Page 11 of 13 1 2 … 9 10 11 12 13
Re: 10 inch lift for gen 2 montero [Re: Angelo] #997776 11/17/12 01:20 AM
StockRaider Offline
solid axle bolt to the front end and add as much lift as you want lol <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 10 inch lift for gen 2 montero [Re: Angelo] #997777 11/17/12 01:20 AM
justice Offline
The guy was a fraud. I'm sure he'll turn up again sooner or later.
Re: 10 inch lift for gen 2 montero [Re: justice] #997778 11/17/12 01:57 AM
StockRaider Offline
I have a bridge for sale if anyones interested... <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
Re: 10 inch lift for gen 2 montero [Re: StockRaider] #997779 11/18/12 02:58 PM
Angelo Offline
From what I saw in the email he sent back to me, he's completed it. It's on 39.5 traxxus tires. Having a hard time posting it from an iPad. Could someone attach the image
Montero on 39.5"
Re: 10 inch lift for gen 2 montero [Re: Angelo] #997780 11/18/12 04:59 PM
justice Offline
Just like all the other photos, he's conveniently posed as to conceal lack of front/rear drive shafts or any steering components. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: 10 inch lift for gen 2 montero [Re: justice] #997781 11/18/12 05:32 PM
And again it's less money to SAS than to drop lift not to mention stronger and more reliable, also all drop lifts are junk. Ask PA_JERO how he likes his drop lift <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 10 inch lift for gen 2 montero [Re: TOASTY] #997782 11/19/12 01:47 AM
Angelo Offline
Justice, I'm in the middle of asking for more detailed pics.
Toasty, how much do you think a SAS would cost. Assuming most of us dont have your skill level. I still think, if he's indeed worked out all the bugs, would be a cheaper alternative. AND assuming he goes with a 4-6" drop kit instead of 10". That wouldnt work at all
Re: 10 inch lift for gen 2 montero [Re: Angelo] #997783 11/19/12 02:00 AM
justice Offline
Good luck with that.
Re: 10 inch lift for gen 2 montero [Re: justice] #997784 11/19/12 05:48 AM
lordtrunks Offline
just leaf spring up the front with a d44 cheap easy works better than ifs i just say this cause your after cheap and easy coil setup wouldn't cost more for the parts just the time for getting the angles correct etc.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 10 inch lift for gen 2 montero [Re: lordtrunks] #997785 11/19/12 07:46 AM
A
awc737 Offline
How it is possible that he said this line: "built upper tubular arm to recieve torsions. still debating wether to use those in the kit or coilovers. I am now starting almost from the begining."
and then in a later post that same day said he had 9 other kits?
Anyway... if you're legit I'll pay you to lift my mighty max 10 inches smile
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.6507 MB (Peak: 0.7745 MB) Data Comp: Off Server Time: 2026-11-11 09:32:07 UTC
