Fixing the under side.... before and after pics. #998253 05/28/10 03:20 AM
TainterRacing Offline OP
I used some epoxy stuff I had laying around I did a test area and then I sprayed 1/2 of it I have to do the front part yet I used 1 qt will put a 2nd qt on yet and I think I will put a 2nd coat on it come fall I used a hammer to get the rust off and a pressure washer.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Fixing the under side.... before and after pics. [Re: TainterRacing] #998254 05/28/10 06:54 AM
Nice although it makes me think it's the underside of the Tin Man. <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Fixing the under side.... before and after pics. [Re: off-roader] #998255 05/28/10 07:31 AM
I was thinking the same thing about the Tin Man as I was reading that.
Punctuation, anyone?
Re: Fixing the under side.... before and after pics. [Re: JohnnyBfromPeoria] #998256 05/28/10 08:34 AM
LandRaider Offline
Tin Man Indeed
Re: Fixing the under side.... before and after pics. [Re: LandRaider] #998257 05/28/10 02:43 PM
89montero Offline
I would have used black but looks good and should help protect it form salt and other [email]cr@p.[/email]
1989 Montero 4dr V6 3.0l
Re: Fixing the under side.... before and after pics. [Re: TainterRacing] #998258 05/28/10 03:52 PM
Glock24 Offline
Wow, that was rusty! You probably needed to sand away the rust before applying the epoxy.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: Fixing the under side.... before and after pics. [Re: 89montero] #998259 05/28/10 03:52 PM
RECON45 Offline
I was thinking about the Tinman from the Wizard of Oz as well. At least with this color if you get a leak you will spot it pretty easy.
Re: Fixing the under side.... before and after pics. [Re: RECON45] #998260 05/28/10 04:30 PM
cdl1701 Offline
After painting that I am sure HE looked like the Tin Man... I know I would have. <img src="/forums/images/graemlins/lol.gif" alt="" />
I have been going over mine with POR-15 it is brush on so not as easy but no need to get all the rust off with that stuff.
88 Montero, 2.6 Black
Re: Fixing the under side.... before and after pics. [Re: cdl1701] #998261 05/29/10 01:19 AM
I thought about doing POR-15 but I had this laying around so it was free I think I am going to paint the wheel wells black so it don't sick out as much.
Re: Fixing the under side.... before and after pics. [Re: TainterRacing] #998262 05/29/10 02:47 AM
Inyo_man Offline
What do y'all think about the spray on bed liner?
It seems to work nicely on skid plates and wheel wells, and it's really easy to apply if you prep the area.
Would something like that work for an undercarriage?
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6405 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-06-04 01:38:01 UTC
