Starion block question
#999038
06/03/10 06:53 PM
I'm finally ready to start working on gathering parts for my Starion motor swap. My plan is to tear everything down to the block and basically build the engin from the crank up. My question is: I have access to an '87 Starion block. Does this block have the oil squirters to cool the pistion? I searched the turbo bible, but did not find the answer.
-Austin
1988 SWB Montero - 2.6L - 5-speed Weber Carb (Coming Soon) Rugged Ridge AVM Hubs
Re: Starion block question
[Re: leadheavy52]
#999039
06/03/10 08:57 PM
Yes, it should. You also need the timing cover and the oil cooler adapter.
[Re: fasteddy]
#999040
06/04/10 05:18 AM
Thanks, fasteddy. I has hoping to hear from you. Tis all I need to know for now, but I'm sure more questions will arise as I progress, but I will check the bible first.
-Austin
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5925 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-10 17:36:08 UTCValid HTML 5 and Valid CSS
