Page 1 of 9 1 2 3 4 5 6 7 8 9
how do 38.5s fit? #999104 06/04/10 08:36 PM
0778drz110 Offline OP
not well... <img src="/forums/images/graemlins/lol.gif" alt="" />
its jacked up, so about 1-2" of lift in these pics
sorry about the crappy pics, had to use the webcam
I hope to have these on by mid-July. I'm going to be running a 2" suspension and 3" bodylift. 4.90 gears. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999105 06/04/10 09:03 PM
Check with the AZ crew. One of them has Lloyd's old 2 door running 35's with the same lift setup you're considering. IIRC, it fit 'ok' but Lloyd did have to do some trimming. Also don't expect to run very quickly with that gearing. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999106 06/04/10 09:05 PM
87Montero Offline
Are you high!?! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: how do 38.5s fit? [Re: 87Montero] #999107 06/04/10 09:13 PM
My front clip is fairly tweaked, Cutting is not a problem.
4.90s, 38s, and drop a gear and its the same as 31s.
No, but I did have some mt. dew today...you just need to stop being a baby <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999108 06/04/10 09:35 PM
87Montero Offline
I just had some MTN Dew today too.. not a fan of this new crap though.. just happened to upload it to my facebook.
Re: how do 38.5s fit? [Re: 87Montero] #999109 06/04/10 09:56 PM
RECON45 Offline
looks good if you are going out on an expedition in iceland. Look forward to seeing it done with the lift. good luck with it.
Re: how do 38.5s fit? [Re: 87Montero] #999110 06/04/10 09:58 PM
I don't like the aftertaste for that one
Favs:
mt.dew/sprite/orange from a can/bottle
coke, mt.dew,sprite from a tap
Re: how do 38.5s fit? [Re: RECON45] #999111 06/04/10 10:11 PM
Thanks, there are some old trails I'd like to take up in NC this summer. I just need a 4.90 rear, BL/shackles/UCAs, gen2 brakes and I'll be set. <img src="/forums/images/graemlins/kewl.gif" alt="" />
V6 front IFS (with spares) with 4.88
gen2 brakes
4.90 rear welded or airlocker
3" body lift
2" suspension
38.5x15r15 boggers
10k winch
should work great, I don't romp on the gas unless its mud <img src="/forums/images/graemlins/cheers.gif" alt="" /> Plus it won't tip over to easy! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999112 06/04/10 10:42 PM
DRaider90 Offline
Biggest tires you can run stock are used 34"s (33.7"). If you want to run full tread new tires stock, you will be limited to 33"s. So lets do the math:
Stock No Lift: 34" Tires (Used)
+ 3" Body Lift: 37" Tires (Used)
+ 2" Suspension Lift: 39" Tires (Used)
Stock No Lift: 33" Tires (New)
+ 3" Body Lift: 36" Tires (New)
+ 2" Suspension Lift: 38" Tires (New)
Lets consider gearing next. Moving up to 4.88s from 4.62s will just about account for 2" of tire size.
34"s w/ 4.88s = 32"s w/ 4.62s
36"s w/ 4.88s = 34"s w/ 4.62s
38"s w/ 4.88s = 36"s w/ 4.62s
You are really pushing the limits of the vehicle, but more power to you in my opinion. You will be setting the bar for what the stock trucks can handle. Right now the largest that has been run is 35"s with the IFS/Stock Setup. Between you running the 38.5"s and me running the Q78s (36") we will cover the upper end of what the stock trucks can handle. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: how do 38.5s fit? [Re: DRaider90] #999113 06/04/10 11:14 PM
I could cut the fenders and run it with 2" lift if I wanted to. <img src="/forums/images/graemlins/kewl.gif" alt="" />
There is PLENTY to cut before you begin to mess with the inner fenders.
Front:
(with straight tires) it didn't touch. The back side of the fender can be cut a good 4" or so. the top about 1-2" and the front can just be cutoff up to the turn signal.
Back:
In the back it rubs the bumper and forward part of the fender opening. You can cut a good 1-1.5" out of the entire rear opening,flush with the tub/inner fender.
Could use a dead blow hammer in some spots too.
PHP: 7.4.33 Page Time: 3.723s Queries: 16 (0.007s) Memory: 0.6516 MB (Peak: 0.7810 MB) Data Comp: Off Server Time: 2026-11-15 15:31:33 UTC
