Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: how do 38.5s fit? [Re: JohnnyBfromPeoria] #999144 06/07/10 04:59 AM
I'll add my 35x13.5R15 Toyo M/T 79.4lbs with no wheel <img src="/forums/images/graemlins/smile.gif" alt="" />
39.5x13.50R15 IROKS weigh 76lbs just sayin'
Re: how do 38.5s fit? [Re: TOASTY] #999145 06/07/10 09:48 AM
LandRaider Offline
Well.. FWIW, IMHO, these 36's are getting twards the limit of what I would call daily driver suitable for MY Gen1 SWB. I can get on the interstate, and climb hills just fine, but I don't know if it could handle 37's. AND I'm running a more powerful engine with better gearing in the trans, and transfer case. Offroad, everything is fine.
I guess if I had v-8 power it might be dooable. My truck does not feel tippy or dangerous... Just a TAD underpowered.
With 31's my big raider will SMOKE the tires down in 2wd, and do some SERIOUS holeshot action in 4hi. I should put some ET Streets on, and run it down the dragstrip one day. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: how do 38.5s fit? [Re: LandRaider] #999146 06/07/10 11:12 PM
0778drz110 Offline OP
Whats been going on with your diesel raider? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999147 06/08/10 01:28 AM
LandRaider Offline
[Whats been going on with your diesel raider? <img src="/forums/images/graemlins/smile.gif" alt="" />
Diesel rig is down for a week or so. I installed the OEM air filter housing that I got from the UK, and I'm waiting on the filter for that. I cleaned some more wiring up, and changed the oil / filter.
I need to get the correct firewall and core support brackets to attach the intercooler frame to the truck. I've got the hoses, frame, and IC... Just need to attach it somehow. Then... It's hole in the hood time. smile
I had custom AC hoses made up to be able to use an OEM compressor, but the compressor on this motor is locked up.... <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> SOOOOO I'm shopping for another compressor... When that gets in, itll be AC time.
After I get the IC put on, and AC working, and all the little issues sorted out, I'm going to start shopping for WVO things, and then put on some 32's, and repaint it.
Re: how do 38.5s fit? [Re: LandRaider] #999148 06/08/10 03:09 AM
french fry burner-cool! <img src="/forums/images/graemlins/smile.gif" alt="" />
I wish I could find a 4d55 from a rainja around here to swap in <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: how do 38.5s fit? [Re: 0778drz110] #999149 07/20/10 03:14 AM
bump
I got some 15x14 6lug wheels to replace the 15x10? 5x5.5 wheels
Remember, no lift yet.
Try to tip it over now <img src="/forums/images/graemlins/nana.gif" alt="" />
The tires rub and can't move on the front. They wouldn't fit on the back. I'm looking at cut fenders and smoothed inner fenders, 1.5" front lift/2" rear shackle, 2" body lift.
I might try racing the stock class at RYC? I'm sure I can beat a jeep...
this is one of the "2.5 ton up" trucks <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: how do 38.5s fit? [Re: 87Montero] #999150 07/20/10 03:27 AM
Inyo_man Offline
Ready for an Iceland expedition with those puppies!
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: how do 38.5s fit? [Re: Inyo_man] #999151 07/21/10 03:45 AM
Lloyd Swartz Offline
Just an FYI I never trimmed for 35s, just lift.
For a gen I V6, 35s are definately max with lift, 5:29s and t/case gears. If you wheel it, you will break some stuff as well. Gen II with DOHC gives you some more power and drivetrain strength to go larger without serious breakage.
Re: how do 38.5s fit? [Re: Lloyd Swartz] #999152 07/21/10 05:18 AM
I agree with you on 35s on the rocks, but down here the terrain is a lot more forgiving. I doubt anything will break even with the 4cyl axles, but I have V6 axles waiting if they do. I'm a light footed driver though too. I hope these boggers will help me out, the BFG A/Ts don't bite good enough with the kind of power/speeds I have. I don't need the low gears or 5.29s, it won't be a highway vehicle <img src="/forums/images/graemlins/wink.gif" alt="" />
I'm hoping to keep it as low as possible. There is plenty to cut in front and back of each tire, but the top is whats limiting me right now. I'll have to go stuff the front tires and estimate how much to cut for the 38.5s...
Re: how do 38.5s fit? [Re: 0778drz110] #999153 07/21/10 07:28 AM
I really wanna whip out the pic of my gen 2 on 40's now but i think i can resist <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6530 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-11-19 23:55:21 UTC
