Oil leak #999501 06/09/10 02:40 AM
Torsion Offline OP
I have an 89 raider 3.0 V6 that has an oil leak that appears to be coming from the rear oil pan area. It's fairly constant leaving a grapefruit sized puddle when I shut it off. Pressure is fine. One time I checked the bolts on oil pan and they were somewhat loose, so I tightend the ones I could reach. Couldn't get to the back ones. It helped some, but has returned. I'm also afraid it could be the rear main seal, don't know for sure. Question: what needs to be done and how diffacult would it be to change rear main seal and oil pan gasket? Thanks.
89'Dodge Raider 3.0 V6, A/T
LSD, KYB equipped
Re: Oil leak [Re: Torsion] #999502 06/09/10 02:48 AM
hazy_daze Offline
Rear main seal: tranny has to come back to get at it.
Oil pan gasket: Either raise the engine slightly or drop the front pumpkin to give you enough room to get the pan down. Use Fel-pro P/N OS30570T following the included instructions...
PHP: 7.4.33 Page Time: 4.359s Queries: 15 (0.003s) Memory: 0.5881 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-06-21 01:42:30 UTC
